whats wrong ps3 driver
i just swapt my blu ray LASER, but when i put i back togetter, i dont want to read disc or put the disc out....
any tips
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
probably the best thing to do would be to take the drive back apart and make sure it was assembled correctly and all the electrical connectors are plugged in. Hope this helps.
Good Luck,
Cody
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
to bad.....its not a step by step gudie on this
из
yeah i have done a few of them and they can be a pain...one of the biggest things is to make sure that that disc sensor on top of the drive is plugged in i think the wires run down the left side of the drive if it is facing you....it is a tiny little connector with small red and black wires running from it
из
Добавьте свой ответ
DANIEL bernesdsd буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 920
