4-дюймовый iPhone выпущенный в марте 2016 года на той же самой платформе, что и 6s. Доступен в серебристом, сером, золотом и розовом цветах с 16/64 Гб памяти. Модели A1662 и A1723.
1049вопросов Показать все
WiFi is weak after screen replacement
I just made a screen replacement for iPhone SE by myself. I carefully followed videos found online and everything works well after the replacement except the Wi-Fi. The iphone can only find Wi-Fi signal when it is very close to it? I know that it might due to I disturbed wifi connection during screen replacement but how can I fix it? Where should I fix! Thanks in advance!
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Hi,
The drop of the phone or yourself has either disturbed the connection between the wifi flex and the logic board, or you have damaged the wifi flex.
Look at the image provided, the wifi flex connects underneath the logic board, you will have to take the logic board out to reconnect it, or replace it. :-)
This is a picture of the part:
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
it has to do with what the replacement screen is made of the wifi singal is maxed out i close case and signal is gone also iphone is much hotter after install
из
Добавьте свой ответ
Bowen Cao будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,316
