Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
iPhone 6 has random restart problem after 10.2 update
I have a iPhone 6 that started having random resets after the 10.2 update. Phone was fine before update with no reboot problems. Went thru trouble shooting with crabapple support and went thru all thier trouble shooting steps.
Final step was torestored the phone in recovery mode and setup as new phone. This did not fix the problem. Apple refused to admit the software ware could be the problem. From info I have found others are reporting the same rebooting issue with thier iPhone 6. Of course apple said I could buy a new phone as this one Is 30 days out of warranty.
Anyone have any suggestions to fix it?
Это хороший вопрос?
Оценка 3
Добавить комментарий
3 Ответов
Выбранное решение
I have been seeing this a lot in my shop the past week... A new battery seems to be the only reliable fix.
Был ли этот ответ полезен?
Оценка 5
2 Комментариев:
Apple strikes again with planned obsolescence through iOS updates!
из
What rneely is saying, use a good quality battery (I highly recommend iFixit's) and if this issue remains after wards, back-up, restore from DFU, then restore your data. The longer you wait, the less likely you are to get your data back in case you haven't back-up yet.
из
The fix was replacing the battery. Apple needs to extend battery replacement to the 6. The software test apple uses to test the battery is not accurate. Replaced battery 1 week ago and 0 resets. Kid at Birmingham Genius Bar and manager acted like a jack$$$. Arregont.
Оценка 0
hi my iphone se is randomly restart and it happend all of the sudden . sometimes screen goes with noisy black & white colors and turn of its like freezing or hang and i should do the hard reset to turn it on.i restored it over itunes and dfu mode .i using ios 10.2.1. any help?
Оценка 0
Добавьте свой ответ
scottingram будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 11,929
