How can I repair it?
I accidentally plugged my sansa cable into my ipod nano 8g 3rd gen. I unplugged it and replugged it into my mac using the correct cable, but the ipod now does not show up either on itunes or on the mac's desktop. Can I repair this, and if so, how
Это хороший вопрос?
4 Комментариев
Thanks for your 3 coments. First, I was mistaken about the ipod still charging--it does not charge or appear on itunes. I have plugged the ipod into another computer with no results. I am not sure if I can reset it without it appearing on the computer. I will look into that. As to the comment from harry, I think it is possible that I may have somehow damaged or bent the pins, but am not sure what they should look like. Under a magnifying glass,(With the back of the ipod facing up) the 2 pins on either end and 2 in the middle are further down (that is, towards the front of the ipod)then the other pins. I am not sure what the pins should look like , so I don't know if this is normal or not, and if not, which way I should push the pins.
из standan
I did reset it, but to no avail
из standan
Does the ipod show up correctly on a different computer?
из Rich Quackenbush
how did you reset it?
из corey0721
