Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
iPhone 5 speaker not working after screen replacement
i repaired the screen on my iphone 5 myself and once it was installed the speaker sound was distorted. So i replaced the speaker with a new one but now there is no sound at all, whether i play music or get a phone call. The phone only vibrates. If i use headphones, the sound comes through. Any ideas what has caused this? and if it is repairable?
Thanks!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Did you use gloves during the repair because the oil on your fingers on those gold connections can cause you some problems. Clean all the connector or gold parts with some alcohol, and put bad together. Also the iPhone 5 speakers are a little tricky you have to make sure that metal connected correctly so the metal points on your cable are touching the correct location of your speaker
Был ли этот ответ полезен?
Оценка 2
5 Комментариев:
The gold contacts on the Lightning dock
из
You mean the metal connectors on the underside of the speaker? And the contact points that are, i believe, on the logic board?
Which cable has connector points for the speaker?
I didnt wear gloves
из
I'm not sure which speaker is being talked about because there are two speakers one is the earpiece speaker which is right at the top of the screen and the loudspeaker which is at the bottom right of the phone.
The earpiece speaker has gold connector springs which connect to some gold round connection points on the front camera ribbon / flex cable assembly.
And if the loudspeaker does not work then it may be that the charging port cable was ripped but this only happens if the charging port assembly was pried out.
из
Its the loudspeaker. I pulled it out again yesterday and cleaned the connectors but it still doesnt work...
Havent removed the charging port either :/
из
I say try another loud speaker as you said the original one became distorted then you tried an replacement one and that did not work at all which I think means bad replacement part.
из
Добавьте свой ответ
lazireth будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,225
