The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
149вопросов Показать все
No Thermal paste on 2nd IC
Hi, I'm cleaning my macbook air after a coffee spill and have disassembled the logic board. when removing the heatsink I noticed that only onw of the two ICs had thermal paste. when I reassemble should I apply thermal paste to both ICs or only the one that had this one initially
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Yes, you should put thermal paste on both of them.
One is the CPU die. The other is the hub controller die.
https://cyberraiden.files.wordpress.com/...
Был ли этот ответ полезен?
Оценка 1
5 Комментариев:
Whoops! Not Correct!
The Haswell series has an intergraded GPU chip (the smaller chip on the carrier). The CPU & PCH are combined on the larger chip.
As for thermal paste Intel recommends not applying thermal paste on the GPU element (Yes I know it sounds a bit odd). I think the issue here is the transference of heat from the CPU/PCH to the GPU.
Here's a bit more on the chip: On-Package PCH, The First Single Chip Haswell
из
@danj You can go argue with iFixit because I got the information from the teardown.
Step 10.
MacBook Air 11" Mid 2013 Teardown
из
Take a look at the either of these IFIXIT guides: MacBook Air 11" Mid 2013 Heat Sink Replacement or MacBook Air 11" Mid 2013 Logic Board Replacement note the small chip is bare.
из
@danj I think it would be a good idea to put thermal paste on the Intel platform controller hub regardless.
из
Ha, it's a GPU.
из
It truly doesn't matter what the IC is. If it's under a heatsink and has its own contact piece, it won't hurt to put thermal paste on it.
Оценка 1
Добавьте свой ответ
J Lycklama будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 1,777
