ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
ΠŸΡ€ΠΈΡΠΎΠ΅Π΄ΠΈΠ½ΡΠΉΡΡ ΠΊ сообщСству Ρ€Π΅ΠΌΠΎΠ½Ρ‚Π½ΠΈΠΊΠΎΠ² - Π‘ΠΎΠ·Π΄Π°ΠΉ Π°ΠΊΠΊΠ°ΡƒΠ½Ρ‚
MFC-240C does not print - despite fresh cartridges and multiple purge
My Brother MFC-240C prints in black, but in none of the colors. I have already installed new original Brother ink cartridges, and executed multiple Normal/Power Purge runs (using the Maintenance Mode as described in the service manual, chapter 9 / 9-43). The problem persists.
Can anybody help? Has anybody successfully disassembled the printer, and cleaned manually the ink supply tubes and/or the printing head?
ΠžΡ‚Π²Π΅Ρ‚ Π½Π° этот вопрос Π£ мСня Ρ‚Π° ΠΆΠ΅ ΠΏΡ€ΠΎΠ±Π»Π΅ΠΌΠ°
Π­Ρ‚ΠΎ Ρ…ΠΎΡ€ΠΎΡˆΠΈΠΉ вопрос?
Π‘Ρ‡Π΅Ρ‚ 2
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
1 ΠΎΡ‚Π²Π΅Ρ‚
НаиболСС ΠΏΠΎΠ»Π΅Π·Π½Ρ‹ΠΉ ΠΎΡ‚Π²Π΅Ρ‚
Print head could be clogged and needs some cleaning. Check Youtube for videos on cleaning...Ink have expiration too, it could be old and dry.
Π‘Ρ‹Π» Π»ΠΈ этот ΠΎΡ‚Π²Π΅Ρ‚ ΠΏΠΎΠ»Π΅Π·Π΅Π½?
Π‘Ρ‡Π΅Ρ‚ 2
2 ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠ΅Π²:
Thank you for your suggestion. It is absolutely correct. I have disassembled the entire printer with the help of a detailed service manual for MFC-240C. This is necessary as the print heads of Brother inkjet printers are located deeply inside the printer. Cleaning the printhead with distilled waters, followed by some purge operations (in the printer's service mode) helped.
All colours appear again perfectly. My old printer got a second life :)
ΠΈΠ·
You are welcome. Where can I see the service manual for MFC 240-C, I hope you don't mind?
ΠΈΠ·
Π”ΠΎΠ±Π°Π²ΡŒΡ‚Π΅ свой ΠΎΡ‚Π²Π΅Ρ‚
Markus Π±ΡƒΠ΄Ρƒ Π²Π΅Ρ‡Π½ΠΎ Π±Π»Π°Π³ΠΎΠ΄Π°Ρ€Π΅Π½.
Бтатистика просмотров:
Π—Π° послСдниС 24 часов: 0
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 3
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 18
Π—Π° всё врСмя: 2,363
