Released December 8, 2009, the Toshiba Satellite L455D-S5976 has a silver upper case and a silver/black lower case. It has a 15.6 inch screen with TOSHIBA written in all capital letters on the back of it.
11вопросов Показать все
I can't get the wh-fi to come on I've tried everything except finding
Can you please tell me where the Wi-Fi switch is located on my Toshiba Satellite ? L445D-S5976? I have looked on both the side and the front of the lab, and even on the backside and also the bottom?
Это хороший вопрос?
Оценка 0
1 Комментарий
Can you give us a bit more here. Many models now have a software function to enable/disable the WiFi.
Are you have a problem getting it to work?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Kim Jones, Here are couple links that may help get your WiFi up and running, just click on the links and scroll down through the info/suggestions. Good luck.
https://www.techwalla.com/articles/how-t...
http://www.tomshardware.com/answers/id-2...
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Kim Jones будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 77
