Battery
en
1 ответ 0 Оценка |
I can't get the wh-fi to come on I've tried everything except finding |
1 ответ 0 Оценка |
How do I check to see if my motherboard is bad? |
1 ответ 0 Оценка |
HOW TO FIX THE CD/DVD drive or replace? |
1 ответ 1 Оценка |
Why is my cooling fan not working |
Инструменты
Вот некоторые основные инструменты, используемые для работы на данном устройстве. Вам, возможно, не понадобиться каждый инструмент для каждой процедуры.
Background and Identification
The Toshiba Satellite L455D-S5976 came on the market in the later part of 2009. It has a 15.6 inch monitor, 250 GB drive, AMD CPU operating at 2.1 GHz and an AMD GPU. The price ranges from $200-$1000. On Amazon.com the product has received an average of 3.5/5 stars and has been repeatedly mentioned as a reliable and a great basic system.
To identify your device, locate the largest black and white text square on the bottom of your computer. There will be a label that says "Satellite L455D-S5976" written in black directly underneath a white label that says "Toshiba." If the numbers and letters do not directly match then you have a different computer than the one described in this page.
Troubleshooting
If you are having trouble with your device, check out the Toshiba Satellite L455D-S5976 Troubleshooting
