The Gateway NV52 was released in 2008. It is similar to the MS2274 and NV5207u models.
Вопросов 13 Показать все
which monitor controller can I use for this laptop
My laptop stopped working, and I'm not interested in fixing it, but I want to use the monitor as a second display for my station, but I need a controller [if I understood correctly], can someone instruct me which controller to get?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
@carrotsy that will depend on your display panel, not your computer. Disassemble your dispaly to the panel and take a look at the label on it. Most common panel for your model is a B156XW04 (there are different version recognized by the V.X number on that label. With that number do a search on either Alibaba.com or ebay.com for a "universal LCD controller board". You should find something like this. Again, always double check your LCD panel. To connect the kit is actually pretty easy. Check this guide for a bit of an idea what you are getting into.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
I guess I was wrong again.
из
@pccheese not wrong you just have not build one yet. You are getting there, reps are looking good.
из
Добавьте свой ответ
Salah будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 202
