This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
Why is the right side of my phone screen flickering?
I bought my device on Amazon in September of 2016. I had no problems the first couple weeks I got it. Then one day half the screen started flickering specifically the right half. There are coloured lines and it is shifted. It is still responsive and strangely when I rub on the flickering half it will take its time and clear up but will return to flickering and jumping once I stop rubbing it.. When I take screen shots the flickering doesn't show either. The picture comes out clear. This is a picture I found on line of a G4. My screen sometimes looks like that, other times its clearer and resembles the normal half of the screen and whatever is on it. I did not drop my phone in water or drop it before any of this started. I have tried factory resets and disabling hardware overlays and none of that worked. http://m.imgur.com/v2aWo6C?
I'd appreciate any help other than sending it back to the person I purchased it from.
Это хороший вопрос?
Оценка 2
1 Комментарий
seem to see alot of people having this issue , you would think someone from lg would be on it , these phones get to be expensive , not very durable
из
Добавить комментарий
Ответов (6)
Наиболее полезный ответ
The same problem started today on my LG V10 H961N. Need some help please.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
That's sad. I'm still with this problem on my LG V10. Another problem is that I bought this phone in another country, so, in my country I don't have anywhere to fix it, because this phone isn't produced here.
из
So did any of you find a solution? Mine started flickering now, after a year - exactly when the guarantee stopped... is it the software or is it a hardware problem? I'm really clueless and very desperate...
из
Today i'm with the same problem in my LG V10. Did you fix it?
Оценка 0
1 Комментарий:
and this happened to my LG V10 H691N
did you have solution ??
Оценка 0
1 Комментарий:
No luck, sorry.
из
I've had this happen on two of these phones. No more LG Phones for me.
Оценка 0
I tried everything and the only thing that worked is installing an app called "screen filter" available for free on the play store. It resolves the flickering issue by adjusting the brightness level.
Let me know if it worked for you guys too.
Оценка 0
https://youtu.be/zUG4iVJxCBQ
Оценка 0
Добавьте свой ответ
Alexandria Green будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 4,844
