How can I permanently disable wifi from the 2ds
on the 3ds there is an antenna . the 2ds doesn't have it
Это хороший вопрос?
Это хороший вопрос?
you dont need to cut any cables, you can setup a PIN code to access the options and just delete all the internet connections and set the pin code up so that nobody can access the settings to setup a connection, pretty much the same effect as removing the WIFI antenna..
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 20
За всё время: 1,255
Other answers say parental controls. That solution does not work for me. The child still can call nintendo to disable them..
из Samuel Hilton
