Released 2008, identified by model number DC24.
My vacuum is very, very loud
I have replaced the the brush thing and a hose that had a hole in it. But it is still very loud.
Это хороший вопрос?
Оценка 1
2 Комментариев
After emptying my Hoover yesterday I switched it back on and it sounded so raw and so loud ... I checked the fan belt and the brushes.... Why has it suddenly become so loud i wonder. ....h e l p !
из
Mines doing the same thing but screeching noise here and there, might be just the old age.
из
Добавить комментарий
Ответов (1)
Выбранное решение
@emess117 , Eileen, There could be a few reasons for your vacuum making more noise then usual, Recheck the canister/filters for proper installation and the brush head assy. also for brush/belts installed properly. I posted a couple links below that may help you trouble shoot the noise and then replace/repair the faulty part. If still under warranty contact Dyson last link below, for parts/repair/replacement/refund. Good luck.
http://www.repairmydyson.com/strange-noi...
https://www.youtube.com/watch?v=cuqtw0Fs...
http://www.dysoncanada.ca/en-CA/support....
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
It sounds like the HEPA filter inside the ball - if the rubber seal is no longer fitting tightly it allows air to flow through the gap, creating the howling noise. A new seal should fix it (from ptlkmxyz).
из
Добавьте свой ответ
Eileen будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 4
За последние 7 дней: 11
За последние 30 дней: 65
За всё время: 39,072
