Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
My the device doesn't turn on.
Hello all,
I have this issue with an iPhone 5s. The screen went blue a couple of times then after a while the device didn't turn on anymore. I'd like to invest some time and money into trying to fix it, even if it doesn't worth it overall, for the sake of learning.
So, I checked the battery and when fully loaded the voltage seems to be fine. From reading other forums I found out that the main board or the logic board may be the problem. Is there way to diagnose it? I would clearly buy a new one from eBay and try to replace it if that's the case.
Where else should I look? What else can the problem be?
Thank you for taking the time to read this!
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
I would avoid eBay, it's kind of like playing the lottery. I would buy two parts from iFixit
First I would buy this
iPhone 5s Battery
Likely your culprit
You could need to buy this
iPhone 5s Lightning Connector and Headphone Jack
I'm guessing you'll need one or both of those, if it's the board, you'll want to send it out to a repair service, like iPad Rehab
How to replace the battery in your iPhone 5s
iPhone 5s Lightning Connector Replacement
iPhone 5s Battery Изображение
Продукт
iPhone 5s Battery
$29.99
iPhone 5s Lightning Connector and Headphone Jack Изображение
Продукт
$24.99
Инструкция
Сложность:
Модерировать
30 minutes - 1 hour
iPhone 5s Lightning Connector Изображение
Инструкция
Сложность:
Модерировать
1 - 2 hours
Был ли этот ответ полезен?
Оценка 1
Does the phone not turn on or does it not display? Trying flipping the vibrate/mute switch and see if it vibrates. Also try plugging it into itunes to see if it recognizes it.
Оценка 0
1 Комментарий:
iTunes doesn't recognize it. It's fully off :(
из
Добавьте свой ответ
VRad будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 62
