Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
iSight Camera broken off logic board
Hi, I was just wondering if I could get a workaround if the iSight camera connector on the logic board has fallen off.
Update (01/14/2017)
Это хороший вопрос?
Счет 4
2 Комментариев
Can you take a good picture of what the logic board looks like now and the cable end so we can see. Paste them in a answer below.
из
I have updated my question to provide those images.
из
Добавить комментарий
2 Ответов
Выбранное решение
No workaround. You will have to try soldering this back on. If you have pulled the pads off (they not accepting solder), you will have to run wires for each individual pin, if the anchor pads are still present.
If you have ripped the pads off, I would learn to live without the camera.
Был ли этот ответ полезен?
Счет 3
3 Комментариев:
You will need to insulate the cable end so it doesn't short out anything.
Looking at the images I do see some burnt junk which you should carefully clean off.
из
Im in this same predicament but totally new at soldering. can you offer any tips to doing this without burning everything to shreds??
из
Find some jump logic board to practice on!
из
Hi Reece, I have the same problem. The pads are off. I can leave without the camera but apparently kernel_task can't :D
The fans are turning at their maximum and kernel_task takes 500% of the CPU. Any idea how to tell my Mac to completely ignore the camera?
Счет 0
1 Комментарий:
Sadly, you can't as SMC needs the input from your display to make sure the system is not overheating.
You'll need to get the logic board repaired or just replace it. Sorry ;-{
из
Добавьте свой ответ
tylerhyper буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 27
За всё время: 2,395
