Do I hook OnHub before Netgear router?
I have a Google OnHub router
and a Netgear Nighthawk x10 router.
I have connected them up with
the Onhub as the primary device and Netgear as secondary.
I have also reversed it as
from Modem to Netgear then to Onhub.
In Reno Nevada using Charter Business plan
I get about 65 Mbps download and 5Mbps upload
using Speakeasy Speed test on both arrangements.
Each of the company's recommend I hook up theirs first.
Is one router limiting the performance of the other using them in any particular order?
Это хороший вопрос?
Счет
0
Would you mind telling us why you are trying to use two different routers?
из mayer
That's my question as well. Networks suffer from too much overhead especially if both routers are trying to, well, route.
One thing you don't want to do is connect the second router to the first via the WAN port. the second router should be just a switch or a hub, not doing any routing.
I'd remove one router and add a switch instead.
Mike
из Michael McWhirter
