Digitizer replacement does NOT work!?
I recently bought an iPod Touch 2nd gen with a cracked digitizer. I have replaced many of these in the past, and have done many other numerous iPod repairs on all other iPod models.
So I took off the broken digitizer, and put it the new one. I did not secure it to the iPod Touch, just in case it wouldn't work. I then powered it on to test it. Of course it didn't work! My digitizer was OEM, and was purchased from the same seller that I had bought from before.
I had another OEM digitizer that worked in my house, and so I tried that one. Again, no luck. I then took it all apart, cleaned it, assembled it back together, plugged and unplugged the two different digitizers multiple times, and haven't gotten any response!
Any help? Anyone else have this same problem?
Thanks!
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Sounds like more than the digitizer is broken, open it up and see if anything else is obviously broken.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
I looked, and nothing else is physically broken. It's as dirty as Satan in there though. That's partly why I unassembled it- to clean the iPod.
I sure hope it's not the motherboard. Those are worth more than the iPod itself! :(
из
It might be worth to clean it then.
из
Yeah. I wish I had a tool to REALLY clean it. Any ideas?
Оценка 0
1 Комментарий:
All I can think of is compressed air.
из
Did something work?
Оценка 0
Добавьте свой ответ
iball1804 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 7
За последние 30 дней: 8
За всё время: 4,931
