Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708вопросов Показать все
Intermittent Light Buzzing noise
Hello!
This is incredible and Frustrating at best! I purchased my iMac 27' (mid 2011) Dec 2011. The light buzzing noise just started yesterday! Last night I unplugged power source and held the Power button for 5- 8 seconds, and when i turned on my iMac- no more noise. Watching a movie just now, the faint buzzing noise is back. I am thinking about replacing he LED backlight and or the PSU. Should I try to purchase online or go through Apple? (no more warranty) - I'm so sad. Previous to this Mac I had a G4 which lasted me 12 years! (believe it or not- I shut down ever night). Any suggestions would be greatly appreciated. -Toronto Canada
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
It's probably a bad capacitor trying to fail. See if you can listen to its location to try to determine where it failing.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Hi!!! Thanks for your reply.
I did some research last night and found that many people have had this same issue with the buzzing noise coming from the upper/left back area. Most likely they say it's the PSU power supply that needs to be replaced.
I have an appointment with APPLE on Wednesday- will see what they say. I'll keep you posted.
Thanks!
из
Добавьте свой ответ
Helena Haughey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 352
