Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Why is there no charge port replacement walkthrough?
I'm replacing the charge port on the ipad and there's no tutorial which sucks. I don't know if I should connect the new port on the back of the motherboard a specific way, please help!
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
Hi Felix. That's because it requires micro-soldering.
Micro-soldering flexes is tricky because you can easily melt the flex so this is really beyond what a DIY fixer should handle. If you have the tools and skills to do this kind of work, then you don't really need an iFixit guide ;>).
Look for an experienced micro-solderer in our area.
Был ли этот ответ полезен?
Оценка 4
2 Комментариев:
Thank's! I found this out, currently trying to learn defiantly not ready haha. What's the best way to go about learning how to micro solder?
из
There are lots of great videos on Youtube. Ultimately, ill need a good quality temperature controlled soldering iron and hot air station, flux and good tweezers and go from there.
из
Добавьте свой ответ
Felix Robinson будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 1,048
