Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
Possible Antenna issue effecting signal
Hi there,
I have a iPhone 5S on three which was working fine up until yesterday when the network ended up being stuck on searching. I managed to perform an update and this went away and it started to recognise the network, but then I noticed the signal kept going and it would say "No service".
Curious, I lightly tapped the bottom side of the phone and the signal came back. Now when using the phone, the signal drops and I have to tap it to get the signal to come back. My assumption is that the antenna must be loose but before I go opening up, I thought I'd see what you guys suggest here and double check exactly which antenna effects the mobile signal.
It's not longer under warranty as it's 3 years old.
Many thanks!
Stacey
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Not likely as the antenna is screwed in to the frame, even if its unstuck you should get a constant 1-2 bar signal in urban areas, more likely its IC related, in that a network IC is loose, given the model it may be a better bet to upgrade, we have attempted hot and cold treatment which lasts 1-2 weeks but permanent fixes are hard to come by and expensive.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
That's a shame. I've literally just upgraded to a 5SE and took out a sim only year contract for my wife to use that phone; so upgrading isn't an option now :(.
из
Добавьте свой ответ
whiteforestdogs будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 79
