Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
iPhone 6 stuck on spinning wheel under booting
Hey
-- BACSTORY, MAY NOT HAVE ANYTHING TO DO WITH ANYTHING -- I changed my friends screen and battery a while back, and everything worked fine - he then dropped it and the the two plastic mounts, the hex bolts holding the screen in place screws into snapped off. So the screen couldn't be held down. He decided to use it anyway.
Then the problem:
Suddenly while using it, it decided to reboot, but under booting up it would just stay on the apple logo and then go out saying it had to be charged - when in a charger it kept buzzing(two buzzes like when you plug in the charger) on the apple logo. I thought it was battery related, so I plugged in a spare one, and it went to that spinning circle instead but still buzzing and not going any further. I tried with another screen, and still the same. The coumpuer sees it as a functional phone as iTunes askses for a password on the phone to access it, but since that's stuck on the spinning circle, I'm not able to reset it.
I can't force reset it in third party app since it's seen as a functional phone.
Any suggestions?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
DFU mode - restore - hopefully its fixed, if not take it to your local hardware repairer.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
It can't go to dfu mode - it's a scrapper if I can't get it fixed
из
It should be able to go into DFU mode, DFU mode can only be booted if a charging cable is plugged in via computer or charger.
Make sure you hold home button before apple logo when plugged in to enter recovery mode at least when apple logo appears.
3UTools software has info on how to do it and the software is useful for software restores.
из
Problem is, it dont respond, it have to be seems by iTunes, but for that to happen I have to say okay on the phone, which I can't - I've tried doing it multiple ways.
из
Добавьте свой ответ
Emil Wang будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 714
