The Acer Chromebook C710-2847 is part of Acer's line of low-price netbooks running Google's Chrome OS. The devices are simply constructed needing just one screwdriver to take them apart.
24вопросов Показать все
replacement battery for C710-2847
Purchased a replacement battery for my C710-2847. Came in, was a different shape than the existing one. Existing one is about 3/4" thick (flat), while replacement is larger and triangle shaped. Fits, but I can't get it to charge up. When new battery in place, and unit plugged into ac power, no battery icon shows.
Any idea where I can purchase a flat replacement (AL12B32) 14.8vdc 2500 mah. Or was the one I purchased just so dead I couldn't get it to charge? Should I try another triangular one?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
If you are in USA, then you can order one from Acer's Web store.
Part# AK.004BT.098
"4-Cell Li-Ion 2500mAh Battery" $39.99
Their marketing/ordering/stock part number AK.004BT.098 corresponds to battery model AL12B32, for Acer Chromebook C710.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Rick Miell будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 380
