How to verify if battery is good
I'm trying to repair my Asus Memo pad HD7 (ME173X-1A013A) because when I turn on it, it shows battery red icon for 2 seconds and it turns off
Charger is good
I thought:
- battery to life end
- dirty charging micro usb port
- problem to charge circuit
I tried to clean usb port but nothing.
I opened tablet and I disconnected battery cable for 10 minutes and I connect it again but nothing.
I tried to hold down both power and volume keys for 10 seconds but nothing.
How can I check if battery is good for example?
thanks
Это хороший вопрос?
Счет 1
1 Комментарий:
When you unplugged the battery and plugged it back in, did you first check with a multimeter that all charge in the system had been drained?
из
Добавить комментарий
