Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Dead, no power. All voltage rails test good
So looking for a motherboard specialist who can possibly shed some new light/ideas for me. I'm working on this iPhone 6 that is completely dead. Doesn't recognize plugged in or unplugged w/ good known screen and battery/charging port.
Weird thing is I've literally tested just about every voltage rail from vcc_main to pp_cpu and pp_gpu to 3v0_tristar and literally about 15 other main ones. All test short free and correct voltage.
Phone is not liquid damaged.
Any possible guesses or other ideas to try? I've already replaced pmic twice as well for giggles w/ no improvement.
My next step is to look into bl driver as from my experience this can cause goofiness but once again, incoming and outgoing from that bga test perfect.
Thanks.
Это хороший вопрос?
Оценка 0
1 Комментарий
sir
will u please help me to trace dead iPhone
из
Добавить комментарий
3 Ответов
Выбранное решение
Hi Stephen. When you say you tested the rails, did you measure their resistance to ground or did you measure the actual voltages? You talk about the backlight...does iTunes recognize the board with only a battery and charge port connected?
There is a very real possibility that you have a defective major IC or broken traces within the board.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Unfortunately iTunes doesn't recognize board. I've had iTunes sometimes not even recognize the phone when its just a backlight problem...weirdly. I tested both continuity to ground as well as actual voltages. I believe your right and suspected trace damage.
из
can u please help me to identify the voltage rails of iPhones
Оценка 0
Bl ic chenge butt ishu not sol
Оценка 0
Добавьте свой ответ
Stephen Elliott будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 671
