Rockchip Quad-Core RK3288C Processor, 11.6" 16:9 HD (1366x768), 16GB eMMC, Integrated Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard Memory 2 GB / 4 GB
18вопросов Показать все
Power Jack connection is Damaged. Can this be replaced and fixed?
My mom's Asus Chromebook C201P has a damage power jack after it fell. The power cord will no longer plug in and so it can not be charged. I found the replacement part on Amazon for $10 but curious to know how complicated this is to replace? Do you happen to have a step by step on how to get to it and what it entails?
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Выбранное решение
CarolineM , The link below is a partial tear down to get inside the device to access the charge port. Repairing a loose USB type charge port that is soldered to the mother board is a delicate procedure and when not experienced while fixing could cause more damage to surrounding circuitry because of heat necessary to install new port or to reattach old port. Changing charge port,normally not a job for the beginner. 2nd link below is a video just to show what is involved in replacing, The guy makes it look easy but believe me it is not that easy and if going to attempt work very carefully and do not rush. If not comfortable doing repair have a good local computer repair shop have a look and estimate cost of repair. Good luck.
Asus Chromebook C201 Motherboard Replacement
https://www.youtube.com/watch?v=mXsw03qk...
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
CarolineM будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 2,212
