The iRobot Roomba 4160 is an autonomous vacuum cleaner that vacuums both carpets and hard floor surfaces.
Вопросов 2 Показать все
Roomba Runs for a minute and shuts off
Purchased new battery, fully charged, but only runs for a minute
Это хороший вопрос?
Оценка 1
3 Комментариев
Does it make any noises when it turns off? Does it beep? If so, how many times does it beep?
из
No, it just stops. But it's working now! I unplugged it for a few months, plugged it back in to charge, and it works. No clue what happened. Thank you
из
Hello
Just replace the battery fully charged hit the clean button runs for a couple of minutes and it stops the status light shows up red and the clean button keeps on flashing green Thanks for your help
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
RoombaQueen , Maybe try the battery reset procedure to see if that corrects your issue, you may have to repeat this procedure a few times. See link below on how to reset. Good luck.
https://www.youtube.com/watch?v=s7Lfg0KZ...
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Thank you GREAT video help
из
My 900 series will run for a minute then stop with 4 rising tones - battery is fully charged but its in a vacation home and the temperature is cold, could that stop it? its above freezing but prob in the 40's.
из
Добавьте свой ответ
RoombaQueen будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 6
За последние 30 дней: 16
За всё время: 10,509
