HTC HD2 — это смартфон производства HTC, работающий под управлением операционной системы Windows Mobile 6.5.
installation guide of the motherboard?
Hello and congratulations for the site ....
My problem is that HD2 is no longer able to start some time.
by the various attempts I made with technical, it appears that the problem is the motherboard.
If you can put a guide on how to mount it and maybe buy it from you.
Thanks and good luck!
Это хороший вопрос?
Счет 2
2 Комментариев
Is this item water damaged at all?
I will be making a tear down guide soon.
из
The motherboard will be too expensive to purchase. You can find a working HD2 with a cracked screen or broken LCD and buy it and use the board from it.
If you have insurance through the carrier, pay the $135 and get a replacement phone. (It's $135 for T-Mobile).
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
If you are interested in checking out the teardown and to replace your motherboard, here are the guides that i use. http://forum.xda-developers.com/showthre... and http://pocketnow.com/hardware-1/official... good luck
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Michele буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 24
За все время: 8,982
