F9 key doesnt work and now I cant enable my touchpad pls help
Some tasty beer destroyd my F9 key and now i can't re-enable my touchpad does anybody know how to fix this?
Это хороший вопрос?
Оценка 0
1 Комментарий
Hi, What is the model number of the laptop?
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Can you enter Windows? have you tried the virtual keyboard from Windows that is on screen. Perhaps that might help.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
I am able to enter windows. And i tried the virtual keyboard and sharpkeys but non of it works.
из
Did you also try a combination of working real keys with virtual keys?
из
Hi, Is there an option in Control Panel > Mouse to enable the touchpad? (I haven't got a laptop to find out) or go to Control Panel > Device Manager > HID Touchpads and see if it is disabled. If it is right click on the touchpad entry. and try enable.
из
Every Asus latop got a Dvd within which you get softwares kind of useful .After you install ,or already installed touchpad software, you can see it in right side of taskbar, open it there and enable it.
Оценка 0
Firt step you can use usb mouse external then
Go to …
Setting -> Device -> Touch Pad -> enable your touch pad
Оценка 0
Добавьте свой ответ
Pieter van der Mullen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 781
