Acer Aspire One 722 (модель #P1VE6) — это нетбук, выпущенный в июле 2008 года.
Acer P1VE6 (Aspire One 722) charges but won't boot
Some time ago my son spilled water on top of the closed Acer Aspire one 722-0473. The water rolled off the top and entered through the touchpad/speaker area. When I plug it in, the orange charging light comes on. When I press the power button, the blue power light comes on. It even stays on after I unplug the laptop (battery is charging). When I took everything apart, I did not see any visible corrosion, but it still won't boot.
Do I need a new motherboard?
P.S. The only change I made the the original system was upgrading the hard drive. I purchased official ACER recovery discs.
Update (02/10/2017)
Looking at the touchpad's logic board, it's got some discoloration under what looks like tape (which is holding cables on). Can I peel that off to clean under it?
Update (04/27/2017)
I swapped the motherboard out, and now it is working beautifully!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@datnametakn , Stop charging and powering on the device. Even though you are not seeing corrosion it may be a good idea treat the board and all connections as if they had the corrosion/water on them (this way all connections,etc will be reseated well and clean). Disassemble the device Link #1 video for reference and a general guide Link #2 explaining drying/cleaning electronics that have experienced liquid damage.
Clean put back together and try. Good luck.
https://www.youtube.com/watch?v=PwttJ1L1...
Electronics Water Damage
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
datnametakn буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 11
За всё время: 589
