Dryer does not heat up
No heat while running
Это хороший вопрос?
The kenmore elite dryers have both gas and electric models. Which is yours?
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 2,193
1 Комментарий
kokor48 we need a proper model number to really help you out. You do not give us enough information. Always post a make and model and what you have tried to fix it.
из oldturkey03
