Why will Water filter not turn to lock in place?
Why can't the refrigerator water filter 4396701 be turned to lock in place?
Это хороший вопрос?
Это хороший вопрос?
@lorene56 , Sharon, Compare new and old filter for correct size. Make sure you remove the dust cap/plug from the inlet on new filter. Check to see if all rubber O rings are still attached to old filter and not stuck inside the fridge filter housing. Use a flashlight to look in the fridges filter housing to see if some foreign object is in the way of new filter locking in. Try a little vegetable oil on the new filter cartridges rubber O rings to help it slide easier and lock in. Last of all sometimes it just takes a little more force/strength, let some else give it a try and do not be afraid to give it a wiggle side to side and up and down while pushing in. Good luck.
Был ли этот ответ полезен?
Does the water filter cartridge need to be in a lock position? When I lock, no water comes out. When a quarter turn, water is still dispensing
За последние 24часов: 11
За последние 7 дней: 44
За последние 30 дней: 183
За всё время: 19,146
4 Комментариев
Sharon-if the filter is located in the top right rear of the fresh food section then I experience this a lot. I don't know why, but I have to remove the top shelves to install it. If the filter is located elsewhere refer to LPlaffs answer.
из LadyTech
We tried about a hundred times. In the end, we think the new filter was faulty. WE then put the old one back, using your oil suggestion and it worked!
Now we wait for a new LG filter (expensive!) to install.
из maniespoelstra
The cooking oil did the trick
Thanks
из Tim
AQUA CREST MDL- (AQF-FF46)
There are two O-rings on outside and one O-ring in center. my problem might have been a manufacturing defect but found the center piece with the single O-ring is not recessed enough into the cartridge. Compare your original one to your new one. If that is the case, I took a small pair of diagonal cutters and sniped that piece, so it was shorter. That fixed my problem. it slid right in.
из Wendell Chibroski
