Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624вопросов Показать все
Attempt to repair fan, logic board will not turn on.
Yesterday, my friend send his laptop to me to fix his mac book pro 13' 2012 unibody. I took it apart and look at the fan that is not working well. So i tried heating up the fan using a heat gun without the logic board (i took it apart), it went a little faster, but then the computer shuts off and will not turn on.
plugged in the magsafe charger, it stays green, battery is half when the left button was pressed, SMC reset only blinks the MagSAfe LED for a milisecond, but stays green
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hello, Try applying some thermal paste on the processor heat sink and let to hold
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Kevin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 49
