New SSD boot problems
I have a mid 2012 MacBook Pro 13" After the HD crash I bought a new 500 GB SSD.
I put it in an external caddy, attached it via USB to computer and cloned the hard disk by recovering from the old disk using disk recovery.
SSD will boot while in the caddy but not when installed into the laptop. It is possible to access the files on the SSD while in the laptop but if I boot from the HDD in a caddy or from a USB Boot thumb drive I cannot see the SSD in the set startup disk menu.
When I insert the old hard disk in the computer it boots normally.
This would appear to rule out hard disk cable problems (I replaced the hard disk ribbon cable last year).
Any ideas as to what is wrong?
SSD is a crucial MX300. Thank you.
Это хороший вопрос?
2 Комментариев
So the ssd wont boot at all when its in the MB but it boots from the caddy. And did you try the original drive?
из Cameron
Hi Cameron, Yes, did try original disk internally and it does boot successfully.
из 19pgk49
