Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Bent frame, what are the best alternatives here?
Hi all! I have a iPhone 6 with a screen flickering. I am replacing the screen, and selling it! Problem is, the phone has a large bend on the bottom. Screen almost fits, but there is a lot of air between frame and screen. I have the gtool icorner, and i was thinking i could invest in a head for the sidewall instead. Is this availabe somewhere?
The bend is pretty bad, and it goes trough the bottom of the phone. It is not just on the top where the gtool will straighten. I can also replace the housing, but that is of course a much bigger job, and i would hope straighten it up with gtool would work. What do you guys think? See pictures bellow! Ask me if you would like me to provide pictures from other angels.
Here you can see it with the screen mounted! There are no bottom screws installed here.
Thanks!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
It appears gTool does not make a side wall head for the iPhone 6.
I have used a combination of needle nose pliers to fix before, and filed off any excess.
You may also want to look at this tool: [связанный продукт отсутствует или отключен: IF317-078]
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thank you for the answer. It is a shame they don't make sidewall heads for iphone 6, because i have seen them for iphone 5S and 5. I will try to bend it slightly so the screen willl fit. Thanks. The tool was pretty expensive, i could rather buy a new fram for that price.
Have a nice day!
из
Добавьте свой ответ
Iver будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 425
