Black screen at start up?
At start up the power light comes on, the startup can be heard, the screen remains black and after a minute the fan comes on.
Это хороший вопрос?
Это хороший вопрос?
Hook it up to an external monitor to isolate the problem.
Does your computer fall into this group?
Serial Number ranges:
W8435xxxxxx – W8522xxxxxx
QP435xxxxxx – QP522xxxxxx
CK435xxxxxx – CK522xxxxxx
YD435xxxxxx – YD522xxxxxx
Был ли этот ответ полезен?
Serial Number - W85487U6U70
Thank you. I will get the Apple VGA Adpater.
Lucky serial number, not in the bad cap group.
Useful info +
See if it will start up from your system installation DVD. Hold down "C" key. Go to the second page pull down menu, Utilities -> Disk Utility and see if you can repair the drive. If no drive shows up then replace it.
mayer,
I used the install disk. The imac turned on, chimed, and the imac screen and the external monitor screen remained black. Does that mean that video card is out or that the display is dead? Any other ideas?
mayer,
I obtained an adpater and hooked the imac to a external monitor. On startup the chime occurred and the onlight came on, I then held down the apple key, the options key and the P & R keys. After about 15 seconds the startup chime occurred again. Then nothing on either monitor.
Ideas?
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 1,374
