Dymo LabelManager 160 is fast, compact and lightweight, making it easy to label just about anything, anywhere. Type quickly on the computer-style QWERTY keyboard, edit with one-touch fast-formatting keys and print for perfect, professional labels every time.
14вопросов Показать все
No charge no ink
My dymo keeps flashing low battery sign but I just changed the batteries also I have it plugged into the wall charger I believe this is also causing it to not print probably everything works like it should except there is no writing on the labels once they print out.
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
Наиболее полезный ответ
MAGGIE , You could try another compatible charger as it may be faulty. Clean the battery contacts in machine using a pen with an eraser on he end as it is a little abrasive or a Qtip dampened with 90% Isopropyl Alcohol or better, clean the terminals well and then blow out the dust/debri and change the batteries out for some new good quality batteries and try. Good luck.
Был ли этот ответ полезен?
Оценка 4
In case someone else googles this like I did. I figured it out shortly after. My colleague had inserted a couple of the new batteries the wrong way. Check the direction of the batteries and it should fix this problem.
Оценка 0
I had the same problem. I rechecked how I installed the batteries and sure enough 2 of them were put in the wrong way. Corrected this and labels are printing correctly now.
Оценка 0
On mine I have checked the batterys a few times but it still won’t print, the machine is brand new but there is no ink, the baterys are new and good
Оценка 0
Добавьте свой ответ
MAGGIE будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 16
За последние 30 дней: 76
За всё время: 6,502
