Scientific calculator by Casio with 252 functions and full dot matrix display. It also features a Replay function and seven variable memory.
Why is my calculator showing a decimal as the answer?
Whenever I use my calculator, and do an equation, for an example, 2+2. It would always give a decimal as the answer when clearly it is not. For 2+2, it says 4.0 instead of 4. For 9.2+1.2, it says 1.0 instead of 10.4. I really don't know what to do because I have finals coming up soon.
Это хороший вопрос?
Счет 2
Добавить комментарий
4 Ответов
Наиболее полезный ответ
usually it is shift + 9 to reset all settings on a calculator to default
Был ли этот ответ полезен?
Счет 2
Try SHIFT, then MODE [SETUP], looking through the menu and selecting the mode you want.
Счет 1
2 Комментариев:
How do I get a dot instead of a comma in my iPhone calculator?
из
Caoimhe, please create a new question on this in the main Q&A page. This specific question is on the Casio fx-82ES, so your question will not bee seen by our community.
из
just press shift 9, it puts all the settings back to normal
Счет 0
Yess this happend to me and the answer in press shift + 9 or shift , mode , 3 , = and again =
Счет 0
Добавьте свой ответ
Vanessa Mendis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 32
За всё время: 15,485
