Repair and disassembly information for Logitech's H800 wireless headset. Supports 2.4GHz & Bluetooth. Released in 2011. Model number: 981-000337.
19вопросов Показать все
No sound in left ear piece
Hello,
I just got a Logitech H800 headset over the weekend. I paired it with my Macbook pro, and the sound works fine in the right ear piece, but nothing comes out of the left ear piece. I have it playing via bluetooth.
Это хороший вопрос?
Оценка 0
3 Комментариев
Hi @lambertson27 ,
Have you tried pairing it with another BT device e.g. a mobile phone to prove whether the problem is with the laptop or the headset?
из
@jayeff, Yes, I tried with another computer with both bluetooth and usb and it still had the same issue. Thanks for any thoughts you have on what's going on.
из
Hi @lambertson27 ,
As you have tried all possible scenarios to make it work in 'stereo' unfortunately it appears as though the headset is faulty. I suggest that you follow @lpfaff1 's advice and return it under warranty for a replacement or refund
из
Добавить комментарий
1 ответ
Выбранное решение
@lambertson27 ,Sarah, If you have tried Logitech H800 headset with more then one device and issue still there, return as defective for exchange/refund. There could be something wrong with the left speaker or wiring. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Sarah Lambertson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 1,462
