Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624вопросов Показать все
Can I install Server SSD 2.5inch SAS Drive into MacBook Pro 13” 2012
I would like to enquire i just boughtSanDisk 1.6TB LB1606R Lightning Read-Intensive 6Gb/s SAS 2.5" SSD, MLC, Up to 410MBs Throughput, 3 Year Warranty
i wanna know the PROs & CONs...
https://www.corporatearmor.com/product_i....
My question is ..is it possible for me to install it into my MBP 13” 2012 2.9ghz i7?
Это хороший вопрос?
Оценка 0
2 Комментариев
Here's some good reading on the different drive interfaces: Understanding SCSI, ATA, SAS and SATA
из
This drive is intended for large server systems not desktop or laptop systems. I would recommend you return it and get your money back as just isn't anyway to use it here.
из
Добавить комментарий
1 ответ
Выбранное решение
You MacBook Pro uses a SATA interface so no you can't use this SAS drive as it's not compatible.
Instead you could go with either of these two drives:
  • Samasung 850 EVO. They offer both a 2 TB & 4 TB drives. Samsung also offers an ultra large 16 TB SSD as well (well beyond what most people would need)
  • Crucial MX300 The largest they offer is a 2 TB
Neither SanDisk, Kingston or Transcend don't offer anything larger than 960 GB in 2.5" SATA
The SanDisk drive you listed is quite expensive! Why do you think you need such a drive? Maybe we can offer you some other alternatives.
References:
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
khaidir77 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 618
