The Kindle's big brother, the DX sports a large 9.7" e-ink display that reads like real paper even in bright sunlight.
Is there any way to fix a broken button?
Is there any way to fix a button that has physically broken in half? It is the main toggle button between the menu and back button on the Kindle DX. If it cannot be fixed, is there a new model that would be recommended that is similar. I have very poor eyesight and this model has been very good for me because I can make the font very large and it is not backlit.
Это хороший вопрос?
Счет 1
1 Комментарий
This is a very common problem according to the many DIY "fixes" posted on the internet. Amazon WILL NOT issue a recall or a repair for it.
из
Добавить комментарий
1 ответ
Выбранное решение
Heather Neilson , The button should be replaceable. The first link below shows how to disassemble the device to access the button to change. The other 2 links may have a replacement button for you or you can also do a search using your make and model replacement buttons. If not wanting to tackle the repair pop into a good local cell/computer repair shop, have them take a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.rapidrepair.com/Merchant2/mer...
http://www.powerbookmedic.com/xcart1/hom...
http://www.powerbookmedic.com/Amazon-Kin...
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Heather Neilson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 1,266
