Why does it keep saying "IP address unavailable when I had it online y
It has the IP address in the advanced settings, but won't connect to hot spot.
Это хороший вопрос?
Это хороший вопрос?
It sounds like there is a problem with the hotspot. I would try disabling and re-enabling the hotspot feature. If that doesn't work you may want to try rebooting or find more info.
Был ли этот ответ полезен?
You or someone you may know might’ve changed the hot spot ip address manually, or messed around the configuration.
For PC HotSpot;
For IPHONE user with access to CARRIERS HotSpot;
For androids, or tablet users… i do not know any details in regard for hotspot problems.
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 52
What device are you trying to connect? You may need to delete the connection and try a reconnect. Also, it may be the hot spot is having issues.
из nealhatfield
