The Singer EZ-Stitch Chainstitch Sewing Machine is meant to help beginners create their own fun and creative projects. It can be used to assemble crafts, clothing, pillows, accessories, and more.
7вопросов Показать все
How do I make it stitch? the peal works, the needle moves, no stitches
and yes, i threaded the needle, and it is all looking fine, but when i try to sew, nothing stays. the needle goes in and out and the thread trails uselessly behind.
is there anything to do about this?
peace
K
Update (03/22/2017)
this machine does not have a bobbin. it also came with no instruction manual.
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
stroicielka, The video link below are the instructions to ensure you are setting it up correctly and shows how to thread properly. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=hZMjVYQs...
Был ли этот ответ полезен?
Оценка 2
Have you threaded the bobbin or thread it correctly? Check your manual for proper procedure on this
Оценка 1
a very important tip for bobbins is the direction that you must follow the instructions for the directions in which the bobbin unwinds!
Оценка 0
Добавьте свой ответ
stroicielka будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 8
За всё время: 684
