Model zd8000, 17" Widescreen display, 2.8-3.6 GHz Intel Pentium 4 processor
Вопросов 8 Показать все
My hp zd8005ap does not turn on?
Few days backi was chrging my laptop suddenly i heard a sound like cracking then little burning smell came out after that nothing happening in my laptop . after that i disamble the laptop then i saw a burned mosfet named AO4407(3pieces). now what to do?
Update
thanx for all . i bought the 5 pieces of AO4407 and fixed my laptop. but have problem also of charging . it only charging during off state. in running state charging light blinking . thanx
Это хороший вопрос?
Оценка -1
2 Комментариев
Thank you for accepting my answer and I hope that you got your laptop fixed. Good luck to you.
из
Start a new Question rather than Answering an Answered Question with a new problem. You'll get faster results.
из
Добавить комментарий
Ответов (2)
Выбранное решение
I am not sure what laptop you have. The Mosfet AO4407 in Dell Compaq/HP laptop is part of the charging circuit. So I would further investigate if you have some capacitor issues that caused the Mosfet to short circuit. It's 'fuller' part# is AO4407 If you look it up at Mouser.com, it cross referenced to a chip from ST micro: STS10PF30L. they are readily available. Here is the datasheet http://www.aosmd.com/pdfs/datasheet/AO44... good luck, and may be consider a surge protector in the future...who knows :)
Был ли этот ответ полезен?
Оценка 4
4 Комментариев:
Sorry just realized that you have an HP ZD8005AP I do apologize for my shorthsightedness :)..
из
first time only 2 mosfets burned . after that i remove 1 from the same position then the laptop was working for one week. after that again 1 more mosfet burned. actually their are 4 mosfets at same postion in parrellel line . now their only 1 mosfet remain . what to do?
из
Sounds to me that you have a short circuit in the charging circuit. Also make sure that the laptop is cooling okay. Just wondering if you can use a different power supply just in case the one you are using is having power surges. Here is a little bit more info on the AO4407 http://mayohardware.blogspot.com/2010/04... not the same computer but the same application.
из
+Very nice providing the data sheet.
из
You can buy replacements from ebay for this part but I'm wondering, what caused three of these to fail at the same time...
Оценка 0
Добавьте свой ответ
SIMRAN будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,513
