Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
No cellular service, very weak wifi, no water problems.
My iPhone 6 lost cellular service (No service) and it has very week wi-fi reception (2 bars when next to router - none with a wall in between). I've replaced SIM without success; SIM works on other phone. Phone hasn't been in water, but a light drop on top left corner that chipped glass. Can the antenna go bad or become disconnected? Any other possibilities?
Это хороший вопрос?
Оценка 0
2 Комментариев
Thanks you so much! Is the baseband chip replaceable? I'll check wifi connections later.
из
that chip is specific to each motherboard, the solution would be reballing the chip. A micro soldering job, a little bit more complicated.
из
Добавить комментарий
1 ответ
Выбранное решение
The wifi antenna disconnects sometimes due to shocks but only way to see that is by removing the motherboard from the phone and check the connection.
For the cellular part you can do a quick check by dialing *#06# if the IMEI n* shows is the antenna if doesn't show then you have a baseband chip issue.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
craiger1528 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 79
