Repair guides and support for HP's LaserJet Laser Printer Line, which includes printers with model numbers starting with LaserJet, LaserJet Pro, Color LaserJet, P, M, CP, and CM.
178вопросов Показать все
HP P1005 LaserJet printing with streaks on paper, Cleaning?
This printer was relatively inexpensive and is great for documents in Black & White. Quick, efficient and cheap to operate.
How do I disassemble it to clean the mechanics to get a cleaner printout ?
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Выбранное решение
You could try to clean the print-cartridge area as well as to clean the device paper path if you are experiencing toner specks or dots on the printouts. you might also try to clean the pickup roller. the users manual describes all those steps in detail and is available at http://www.retrevo.com/samples/HP-Printe... as well as http://h10025.www1.hp.com/ewfrf/wc/manua... Good Luck
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Dead links live links are needed to access user manuals.
из
Hi @ dave.trotsky.ireland
Here's a link to the User manual for the P1000 series printer taken from this webpage
из
Добавьте свой ответ
capone99 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 6,416
