broken sd slot needs replaced on my T100
how do I replace the broken microsSD slot?
Это хороший вопрос?
Это хороший вопрос?
thelacys, If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a couple links to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
Asus Transformer T100 Motherboard Replacement
https://www.youtube.com/watch?v=RM_fIU_B...
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 195
2 Комментариев
Thank you so much!
из thelacys
thelacys , you are welcome, thanks for replying back. Good luck with T100.
из L Pfaff
