Are the displays interchangeable
Hi everybody.
There two MBAs 13", Mid 2012 & mid 2011. One has non working keybord, the other one has a non working display.
I couldnt find an an answer so far, if the displays are interchangeable on those models?!
Even comparing pictures didnt help.
Any ideas? Thx for help.
Kind regards from Krautland
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
2010, 2011 and 2012 assemblies are compatible with each other on MBA 13"
Был ли этот ответ полезен?
Оценка 5
3 Комментариев:
@reecee: Hello from Krautland & many thanks for your hint. I haven't worked on MBA's so far, so lack of experience. I find it amazing that 3 different models will fit eachother; usually Apple changes tiny bits and pieces within the modelranges, so that e.g. a slightly different socket will throw a spanner in your works.
I will have the chance to check this out by next week & I'll drop you a line.
Kind regards from
Alex deLarge
из
@reecee: Hello from Krautland! I promised to drop you a line! Sorry for being that late, but a very odd flu had kicked into the gutter. All went extremly well! No trouble to interchange the display between the MBA 13 " 2011 & 20112 models. You are a legend in your lunchbox!
Kind regards
Alex deLarge
из
Glad to hear it went well :)
из
Добавьте свой ответ
Alexander deLarge будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 64
