The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
40вопросов Показать все
Where is the oil pressure switch located?
Where is the oil pressure switch located on the motor?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
On the 2000 inline 6 it is down on the block just above the oil filter. Look for a small cylinder with a wire on one end
Был ли этот ответ полезен?
Оценка 3
On the 3.7L engine it's at the front of the engine above the oil filter, remove filter for better access. Unplug the wiring harness by moving the red safety tab and depressing the lock tab. Requires 1 1/16" deep socket to remove.
Оценка 1
Добавьте свой ответ
Debbie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 3,971
