freezer cold but not freezing
freezer is cold but not freezing
Это хороший вопрос?
Cause 1
The Evaporator Coils are Frosted Over
The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Был ли этот ответ полезен?
chest-style freezers use internal coils, this applies to upright models or refrigerator/freezer combinations. So you should check coils is working properally or not. There are many Causes while your Freezer Which Isn't Freezing anything. these are given below.
Cause 1 : The Evaporator Coils are Frosted Over
Cause 2 : Evaporator Fan Motor
Cause 3 : Damper Control Assembly
Thanks You
How can i get someone out to look at it for me
You need to find an appliance repair company in your area and call them, and schedule a service call.
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 30,407
8 Комментариев
More details. IS the settings set right
из Cameron
Hi @allegra ,
What is the make and model number of the refrigerator?
What is the temperature in the freezer?
из jayeff
The model of my chest freezer is TCF-SD300
the manufacturer is Tamashi
из Godfred
Godfred, whats the issue with the freezer.
из LadyTech
although it cools it does not freeze my food items....is that normal for a chest freezer ?
the name is Tamsahi with the model number TCF-SD300
I HAVE SET THE REGULATOR TO NUMBER 7 BUT STILL NO FREEZING
из Godfred
Показать 3 больше комментариев
