Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
66вопросов Показать все
OP3 Screen Repair and Preventive Maitence
I recently crack my screen on my OP3t... Save the first couple incidents, I found that ordering the parts and doing the labor myself saved a lot of money, It also was kind of fun (yea I am one of those guys). Anyway, Before doing any research what so ever on the tear down and repair I ordered an OEM original piece of glass considering that both the digitializer and LCD were both working well. My confidence rapidly depleted when I started the research and came to the conclusion that this particular repair was beyond my pay grade. I reached out to OnePlus and astonishingly they only charged around $65 USD for the parts, labor and shipping. Which is very reasonable considering that I couldn't find a display assembly for less the a hundred dollars. While my phone was still being repaired the glass I ordered arrived and I was blown away about the quality of glass. So my question is... would I be able to use the replacement glass in place of a tempered glass screen protector? With the glass they send both UV Loca Glue and Mini tools and an UV flashlight to activate the glue that from what I've read dries completely clear.. My fears about this are would it decrease the touch sensitivity of my phone and if no how would I apply the glue. IE. All over the glass or around the corners.... I obviously have no idea but I do know that if this is possible I would be ecstatic! thank you for your time and look forward to hearing the response.. I've attach some photos of the OEM glass, The Glue, My phone (cracked tempered glass, installed yesterday, already Cracked, and then one with the New Glass Over Current Phone. Thank you again,
Randy
Это хороший вопрос?
Оценка 0
2 Комментариев:
Wow! Wish replacements where that cheap for other flagship phones. I couldn't find it on the website, but is the screen an ammoled? Or OLED?
из
Добавить комментарий
1 ответ
Just use normal tempered glass screen protector . Save the spare glass if it needs to be repaired again. Uv loca or oca is hard to apply without tools and will leave many bubbles.Plus the glass is meant to be glued on top of the lcd. You might face some problems if you try stacking multiple layers of glass. Anyway if you try it post results its interesting to see how it will turn out.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Randy Rice будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 1,302
